ARGB add-on for Hard Tubing image number 0
ARGB add-on for Hard Tubing image number 1
  • Input Voltage 5V
  • Diameter 14mm
  • Legacy Cooling
  • Connection Type 3-pin addressable RGB
  • Material PLA Filament
  • Dimensions (L x W x H) Custom made to fit.
  • CPU-Z - Cooler Master 32 & 64-bit versions Download
