CMP 102 image number 0
CMP 102 image number 1
CMP 102 image number 2
CMP 102 image number 3
CMP 102 image number 4
CMP 102 image number 5
CMP 102 image number 6
CMP 102
CMP 102
CMP 102
CMP 102
CMP 102
CMP 102
CMP 102
CMP 102
CMP 102
  • Cooling System - Side 120mm fan x 2 (optional)
  • Cooling System - Bottom 1x 120mm Fan (Optional)
  • Legacy Cases
  • Size Mini Tower
  • I/O Panel 2x USB 2.0
  • Expansion Slots 7
  • Motherboard Support ATX
  • Power Supply Support Standard ATX PS2 (optional)
  • Maximum Compatibility - CPU Cooler Height 156mm / 6.1 inch
  • Series CMP Series
  • Materials Steel body
  • Materials Plastic mesh bezel
  • Weight 3.0 kg / 6.6 lbs
  • 5.25" Drive Bays 1 (exposed)
  • Cooling System - Rear 1x 120mm fan (optional)
  • Maximum Compatibility - VGA Card Length 322mm / 12.7 inch
  • I/O Panel 1x Mic
  • 3.5" Drive Bays 1 (exposed)
  • I/O Panel 1x Audio (supports AC97 audio)
  • 2.5" Drive Bays 2 (hidden, in the HDD cage)
  • 3.5" Drive Bays 2 (hidden)
  • Cooling System - Front 120mm black fan x 2 (one is installed, one is optional)
  • Color(s) Black (interior non-coating)
  • Dimensions (L x W x H) 183 x 424 x 397 mm / 7.2 x 16.7 x 15.6 inch
  • Model Number RC-102C-KKN2
