CMP 320L image number 0
CMP 320L image number 1
CMP 320L image number 2
CMP 320L image number 3
CMP 320L image number 4
CMP 320L
CMP 320L
CMP 320L
CMP 320L
CMP 320L
Cutting Edge Brilliance
CMP 320L
CMP 320L’s unique geode front panel allow for unrestricted airflow and optimal thermals.
Mesh Geode Front Panel
Versatile Cooling Options
Full Black Coating & PSU Cover
  • Model Number CP320-KGNN-S03
  • Exterior Color Black
  • Materials - Exterior Steel, Plastic
  • Dimensions (L x W x H) 445.5 x 204 x 425mm (Incl. Protrusions), 431.8 x 204 x 410mm (Excl. Protrusions)
  • Volume 38.52L (Excl. Protrusions)
  • Expansion Slots 4
  • 5.25" Drive Bays 0
  • 2.5" Drive Bays 2
  • I/O Panel - USB Ports 1x USB 3.2 Gen 1 Type A, 1x USB 2.0
  • Pre-installed Fans - Rear 1x 120mm MasterFan Lite
  • Fan Support - Top 2x 120mm, 2x 140mm
  • Fan Support - Front 2x120mm / 3x120mm (*Installed inside the case only)
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 140 / 240 / 280mm (*Recommend AIO tubes face rear to avoid interference)
  • Clearance - CPU Cooler 163.5mm
  • Clearance - PSU 160mm
  • Clearance - GFX 365mm (without front fans & radiator)
  • Cable Routing 16.5mm
  • Dust Filters Top, Bottom
  • Size Mini Tower
  • Series CMP Series
