CMP 520L image number 0
CMP 520L image number 1
CMP 520L image number 2
CMP 520L image number 3
CMP 520L image number 4
CMP 520L
CMP 520L
CMP 520L
CMP 520L
CMP 520L
Cutting Edge Brilliance
CMP 520L
CMP 520L's asymmetrical front panel design frames any fans that the user chooses to install as unique centerpieces on the build.
Mesh Geode Front Panel
Versatile Cooling Options
Full Black Coating & PSU Cover
  • Model Number CP520-KGNN-S03
  • Exterior Color Black
  • Materials - Exterior Steel, Plastic
  • Dimensions (L x W x H) 439 x 204 x 463mm (Incl. Protrusions), 432 x 204 x 448mm (Excl. Protrusions)
  • Volume 41.34L (Excl. Protrusions)
  • Motherboard Support Mini-ITX, Micro-ATX, ATX
  • Expansion Slots 7
  • 5.25" Drive Bays 0
  • 2.5" Drive Bays 2
  • I/O Panel - USB Ports 1x USB 3.2 Gen 1 Type A, 1x USB 2.0
  • Pre-installed Fans - Rear 1x MasterFan Lite
  • Fan Support - Top 2x 120mm, 2x 140mm
  • Fan Support - Front 3x 120mm, 2x 140mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 240mm* (*RAM height below 35mm)
  • Radiator Support - Front 120 / 140 / 240 / 280mm
  • Clearance - CPU Cooler 161mm
  • Clearance - PSU 160mm
  • Clearance - GFX 350mm (w/o front fans & radiator)
  • Cable Routing 18.5mm
  • Dust Filters Top, Bottom
  • Size Mid Tower
  • Series CMP Series
