Elite 500 / Elite 500 ODD image number 0
Elite 500 / Elite 500 ODD image number 1
Elite 500 / Elite 500 ODD image number 2
Elite 500 / Elite 500 ODD image number 3
Elite 500 / Elite 500 ODD image number 4
Elite 500 / Elite 500 ODD image number 5
Elite 500 / Elite 500 ODD image number 6
Elite 500 / Elite 500 ODD image number 7
Elite 500 / Elite 500 ODD image number 8
Elite 500 / Elite 500 ODD image number 9
Elite 500 / Elite 500 ODD image number 10
Elite 500 / Elite 500 ODD image number 11
Elite 500 / Elite 500 ODD image number 12
Elite 500 / Elite 500 ODD image number 13
Elite 500 / Elite 500 ODD image number 14
Elite 500 / Elite 500 ODD image number 15
Steadfast
Large Filtered Intakes
With/Without ODD Support
Versatile Cooling Options
Full Black Coating & PSU Cover
Room For Upgrades
Removable HDD Cage
  • Dust Filters Top
  • Kensington Lock N/A
  • Dust Filters Front
  • Color(s) Black
  • Size Mid Tower
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Series Elite Series
  • Motherboard Support ATX
  • Expansion Slots 7
  • Fan Support - Top 2x 140mm
  • Cable Routing 18.5mm
  • Volume 37.29L (E500-KGNN-S00, E500-KNNN-S00) (exlc. Protrusions), 42.40L (E500-KG5N-S00, E500-KN5N-S00) (exlc. Protrusions)
  • Fan Support - Top 2x 120mm
  • I/O Panel 2x USB 3.2 Gen 1 Type-A
  • Radiator Support - Front 360mm (Remove ODD) (E500-KG5N-S00, E500-KN5N-S00)
  • Radiator Support - Top 120 / 240mm (32mm max motherboard component height)
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • Clearance - PSU 160mm (E500-KGNN-S00, E500-KNNN-S00), 180mm (E500-KG5N-S00, E500-KN5N-S00)
  • Clearance - CPU Cooler TG: 161mm, Steel: 163mm
  • Fan Support - Front 2x 140mm, 3x 120mm (E500-KGNN-S00, E500-KNNN-S00), 2x 120mm (E500-KGNN-S00, E500-KNNN-S00), 3x 120mm (remove ODD bracket) (E500-KGNN-S00, E500-KNNN-S00)
  • 5.25" Drive Bays 0 (E500-KGNN-S00, E500-KNNN-S00), 1 (E500-KG5N-S00, E500-KN5N-S00)
  • 2.5" Drive Bays 3 (E500-KGNN-S00, E500-KNNN-S00), 5 (E500-KG5N-S00, E500-KN5N-S00)
  • Materials Steel, Plastic, Tempered Glass
  • Clearance - GFX 350mm (w/o front fans & radiator) (E500-KGNN-S00, E500-KNNN-S00), 400mm (w/o front fans & radiator) (E500-KG5N-S00, E500-KN5N-S00)
  • Dimensions (L x W x H) 409 x 204 x 455mm (incl. Protrusions), 402 x 204 x 455mm (excl. Protrusions), 464 x 204 x 455mm (incl Protrusions, ODD), 457 x 204 x 455mm (excl. Protrusions, ODD)
  • Model Number E500-KGNN-S00 (TG), E500-KNNN-S00 (Steel), E500-KG5N-S00 (TG, ODD), E500-KN5N-S00 (Steel, ODD)
