HAF 922 Red image number 0
HAF 922 Red image number 1
HAF 922 Red image number 2
HAF 922 Red image number 3
HAF 922 Red image number 4
HAF 922 Red image number 5
HAF 922 Red
HAF 922 Red
HAF 922 Red
HAF 922 Red
HAF 922 Red
HAF 922 Red
HAF 922 Red
HAF 922 Red
  • Size Mid Tower
  • Legacy Cases
  • Cooling System - Bottom 1x 120/140mm Fan (Optional)
  • Power Supply Support EPS 12V (Optional)
  • Expansion Slots 7+1
  • Cooling System - Rear 120mm fan x 1 (installed, 1200 RPM, 17 dBA)
  • I/O Panel 2x USB 2.0
  • Motherboard Support ATX
  • Series HAF Series
  • 3.5" Drive Bays 1 Exposed (converted from one 5.25" drive bay)
  • Materials Steel body
  • Cooling System - Top 200mm black fan x 1 (optional; can be swapped for two 120mm fans)
  • Gross Weight 10.9 kg / 24.0 pounds
  • Cooling System - Front 200mm red LED fan x 1, 700RPM,19dBA (can be swapped for two 120mm fans)
  • Materials Mesh and Plastic
  • I/O Panel 1x Mic
  • I/O Panel 1x eSATA
  • 3.5" Drive Bays 5 (hidden)
  • 5.25" Drive Bays 5 Exposed (one could convert to 3.5" drive bay)
  • I/O Panel 1x Audio (Support Intel HD Audio / AC 97)
  • Net Weight 8.7 kg / 19.2 pounds
  • Dimensions (L x W x H) Main: 253 x 502 x 563 mm / 10.0 x 19.7 x 22.2 inches
  • Dimensions (L x W x H) Box: 285 x 550 x 605 mm / 11.2 x 21.7 x 23.8 inches
  • Model Number RC-922M-RWN2-GP
