Hyper 212X (EU ver.) image number 0
Hyper 212X (EU ver.) image number 1
Hyper 212X (EU ver.) image number 2
Hyper 212X (EU ver.) image number 3
The hyper 212X includes a PWM controlled fan and provides incredible 9 dBA low noise with a maximum of only 27.2 dBA.
  • Heat Pipe Dimensions Ø6mm
  • Note *AMD AM4 upgrade kit needed, please visit: http://bit.ly/31244ne
  • Legacy Cooling
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Fan MTTF 160,000 Hours
  • Fan Safety Current 0.37A
  • Fan Speed 600-2000 RPM (PWM) ± 10%
  • CPU Socket LGA1366
  • Bearing Type 4th Generation Bearing
  • CPU Socket LGA1200
  • Heat Sink Dimensions (L x W x H) 116 x 51 x 158 mm
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Dimensions (L x W x H) 120 x 79 x 158 mm
  • Fan Air Pressure 0.3 - 2.09 mmH2O ± 10%
  • Fan Noise Level 9 - 36 dBA
  • Heat Sink Weight 492g / 1.1lb
  • Fan Airflow 24.9 - 82.9 CFM ± 10%
  • Fan Weight 106g / 0.2lb
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • Heat Sink Material 4 Continuous Direct Contact Heat Pipes
  • CPU Socket FM2
  • CPU Socket FM1
  • Product Number RR-212X-20PM-R1
  • Fan Power Consumption 4.44W (Max)
