Hyper 412S image number 0
Hyper 412S image number 1
Hyper 412S image number 2
Hyper 412S image number 3
Hyper 412S image number 4
Hyper 412S
Hyper 412S
Hyper 412S
Hyper 412S
Hyper 412S
Hyper 412S
The Hyper 412 series inherits the low noise design of the Hyper 612, featuring optimum heat dissipation at low fan speeds.
  • Heat Pipe Dimensions Ø6mm
  • Cooler Type Air Cooler
  • Connector 3-Pin
  • Fan MTTF 40,000 Hours
  • Legacy Cooling
  • Fan Bearing Type Long Life Sleeve Bearing
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Note *The supplied accessories may differ by country or area. Please check with your local distributor for further details.
  • Series Hyper
  • Fan Rated Current 0.1A
  • CPU Socket LGA1366
  • Fan Power Consumption 1.2W
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • Fan Speed 1300 RPM ± 10% (900 RPM with silent mode adapter)
  • Heat Sink Dimensions (L x W x H) 128 x 70 x 160 mm / 5.0 x 2.8 x 6.3 inch
  • Fan Air Pressure 1.14 mmH2O ± 10% (0.55 mmH2O @ 900RPM)
  • Fan Weight 102g / 0.23lb
  • Heat Sink Weight 507g / 1.12lb
  • Dimensions (L x W x H) 132 x 99 x 160mm / 5.2 x 3.9 x 6.3 inch
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • Heat Sink Material 4 Continuous Direct Contact Heat Pipes
  • Product Number RR-H412-13FK-R1
  • EAN code 4719512035634
  • UPC code 884102015205
  • CPU Socket FM1
  • Fan Airflow 36.4 - 52.6 CFM ± 10%
  • Fan Noise Level 22.5 dBA (16.1 dBA @ 900RPM)
