Killer 102 image number 0
Killer 102 image number 1
Killer 102 image number 2
Killer 102 image number 3
Killer 102 image number 4
Killer 102 image number 5
Killer 102
Killer 102
Killer 102
Killer 102
Killer 102
Killer 102
Killer 102
  • I/O Panel 1x USB 3.0
  • Pre-installed Fans - Front 1x 120mm
  • Materials Plastic
  • Color(s) Black
  • Size Mid Tower
  • 5.25" Drive Bays 1
  • Fan Support - Side 1x 120mm
  • Fan Support - Rear 1x 120mm
  • I/O Panel 1x USB 2.0
  • Fan Support - Bottom 1x 120mm
  • Expansion Slots 7
  • Materials SECC
  • Motherboard Support ATX
  • Power Supply Support Standard ATX PS2 (optional)
  • Materials Mesh
  • Fan Support - Front 2x 120mm
  • 3.5" Drive Bays 3 (hidden)
  • Series Others
  • 2.5" / 3.5" Drive Bays (Combo) 2 (hidden)
  • I/O Panel 1x Mic
  • I/O Panel 1x Audio (Support Intel HD Audio / AC 97)
  • Weight 4.05 kg
  • Dimensions (L x W x H) 183 x 424 x 397 mm / 7.2 x 16.7 x 15.6 inch
  • Model Number RC-102C-KKN4-TW
