MasterBox 5T image number 0
MasterBox 5T image number 1
MasterBox 5T image number 2
MasterBox 5T image number 3
MasterBox 5T image number 4
MasterBox 5T image number 5
MasterBox 5T image number 6
MasterBox 5T
MasterBox 5T
MasterBox 5T
MasterBox 5T
MasterBox 5T
MasterBox 5T
MasterBox 5T
You Decide the Inside
MasterBox 5T
MasterBox 5T
  • Pre-installed Fans - Front 1x 120mm
  • Legacy Cases
  • Dust Filters Front
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • I/O Panel 2x USB 3.0
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Drive Bays - SSD 1
  • Expansion Slots 7
  • Motherboard Support ATX
  • Cable Routing - Behind Motherboard Tray 25-35mm
  • Materials Steel body
  • Fan Support - Top 1x 140mm
  • Materials Plastic mesh bezel
  • Clearance - CPU Cooler 167mm/6.5"
  • Fan Support - Top 1x 120mm
  • Clearance - GFX 410mm/16.1"
  • Dimensions (L x W x H) 541.2 x 220 x 513.5mm
  • I/O Panel Fan Speed Control H/L
  • EAN Code 4719512053706
  • UPC Code 884102029790
  • Model Number MCX-B5S3T-RWNN
