Mini 110 Mini-ITX Case image number 0
Mini 110 Mini-ITX Case image number 1
Mini 110 Mini-ITX Case image number 2
Mini 110 Mini-ITX Case image number 3
  • Maximum Compatibility - CPU Cooler Height 55mm / 2.2 inch
  • I/O Panel 2x USB 3.0
  • Color(s) Black
  • Legacy Cases
  • Size Mini ITX
  • Materials SECC
  • Materials Polymer
  • Net Weight 2.6 kg / 5.7 lbs
  • Pre-installed Fans - Front 1x 60mm Fan
  • 5.25" Drive Bays 1 (exposed, slim ODD bay)
  • Power Supply Support Flex ATX 200W active (installed)
  • I/O Panel 1x Mic
  • 3.5" Drive Bays 1 (hidden)
  • 2.5" Drive Bays 1 (hidden; converted from one slim ODD bay)
  • Dimensions (L x W x H) 268 x 70 x 290 mm / 10.5 x 2.7 x 11.4 inch
  • Model Number MIN-110-KKA200
