PWM Fan 80mm image number 0
PWM Fan 80mm
  • Screws 4 pcs
  • Legacy Cooling
  • Color Black
  • Cable Length 500mm
  • Fan Dimensions (L x W x H) 80 x 80 x 25 mm / 3.1 x 3.1 x 1.0 inch
  • Fan Life Expectancy 50,000 Hours
  • Fan Bearing Type Ball Bearing
  • Fan Rated Current 0.12A
  • Fan Weight 78g
  • Fan Noise Level 12.84 dBA (Min)
  • Fan Speed 2500 RPM ± 10% (100%), 2000 RPM ± 10% (75%), 1400 RPM ± 10% (50%), 900 RPM ± 10% (35%)
  • Fan Air Pressure 2.72 mmH2O
  • Fan Airflow 28.77 CFM
  • Product Number R4-P8B-25AK-GP
