PWM Fan 92mm image number 0
PWM Fan 92mm
  • Screws 4 pcs
  • Legacy Cooling
  • Cable Length 500mm
  • Color Black
  • Fan Life Expectancy 50,000 Hours
  • Fan Dimensions (L x W x H) 92 x 92 x 25 mm / 3.6 x 3.6 x 1 inch
  • Fan Bearing Type Ball Bearing
  • Fan Weight 100g
  • Fan Rated Current 0.22A
  • Fan Noise Level 11.95 dBA (Min)
  • Fan Speed 2250 RPM ± 10% (100%), 1800 RPM ± 10% (75%), 1300 RPM ± 10% (50%), 850 RPM ± 10% (35%)
  • Fan Air Pressure 2.64 mmH2O
  • Fan Airflow 39.30 CFM
  • Product Number R4-P9B-22AK-GP
