Sentinel III image number 0
Sentinel III image number 1
Sentinel III
Sentinel III
Never Retreat. Advance!
Sentinel III
Sentinel III
  • Mouse Grip Type Palm
  • Mouse Cable Length 1.8m / 70.9 in
  • Mouse Connector Cable USB 2.0
  • Mouse LED Color RGB
  • Mouse Color Black
  • Mouse acceleration 50g
  • Additional Weights 5x 4.5 g / 5x 0.009 lbs
  • Programmable buttons 8
  • Angle Snapping Yes
  • Legacy Peripherals
  • Mouse Tracking Speed 200 ips / 50 g
  • Mouse Material Plastic
  • Mouse Material Rubber
  • CPI / DPI 4 Levels / Up to 6400 DPI setting
  • Mouse Sensor Avago 3988 Optical Sensor
  • Mouse Lift Off Distance Adjustable (<2.1mm)
  • Mouse Dimensions 135 x 83.6 x 40 mm / 5.3 x 3.3 x 1.6 inches
  • Mouse Weight 177.5g / 0.392 lbs
  • Mouse Weight 155g / 0.342 lbs (without Weights)
  • Mouse Weight 115g / 0.254 lbs (without Cable)
  • Product Name Sentinel III
  • Product Number SGM-6020-KLOW1
