SK621 White Low Profile 60% Gaming Keyboard image number 0
SK621 White Low Profile 60% Gaming Keyboard image number 1
SK621 White Low Profile 60% Gaming Keyboard image number 2
SK621 White Low Profile 60% Gaming Keyboard image number 3
SK621 White Low Profile 60% Gaming Keyboard image number 4
SK621 White Low Profile 60% Gaming Keyboard image number 5
STRIKINGLY SLEEK
The SK621 White Limited Edition is a truly portable keyboard with low profile mechanical switches.
  • Keyboard Type Mechanical
  • LED Color RGB
  • Product Keyboard
  • Keyboard Response Rate 1ms / 1000Hz
  • Material Aluminum
  • Wireless Connectivity Bluetooth 4.0
  • OS/Platform Support (at release) Bluetooth (Required: Bluetooth low energy technology)
  • OS/Platform Support (at release) Windows 8+
  • Keyboard MCU 32bit ARM Cortex M0
  • On-board Memory 512KB
  • Keyboard Type Wireless
  • OS/Platform Support (at release) Mac OS X 10.10+
  • Software Support Yes, Through Portal
  • Material Plastic
  • Keyboard Weight 424g / 0.934 lbs (without Cable)
  • Multimedia Keys Through Function Key (FN)
  • Color Silver
  • On-the-fly System Yes, for Multi-media, Macro Recording and Lighting Control
  • Color White
  • Cable USB Type-C Detachable & Braided
  • Cable Length 1.8m, Braided & Removable
  • Keyboard Switch Type Cherry MX RGB Low Profile Switch
  • Connector Cable USB Type-C (Keyboard Side)
  • Connector Cable USB 2.0 Type A (Computer Side)
  • Serie SK Series
  • Dimensions (L x W x H) 293 x 103 x 29.2 mm
  • Product Number SK-621-SKLR1-US
