Speed-RX image number 0
Speed-RX image number 1
Speed-RX image number 2
Speed-RX
Speed-RX
Speed-RX
Speed-RX
The Storm Speed-RX is developed specifically for optical gaming grade sensor, but works equally well for high-end laser sensors.
  • Surface Color Black
  • Base Color Black
  • Surface Material Cloth
  • Base Material Rubber
  • Mouse Pad Type Soft
  • Mouse Pad Size Large
  • Mouse Pad Size Medium
  • Mouse Pad Size Small
  • Product Mouse Pad
  • Weight 440g / 0.97 lbs (Size L)
  • Weight 210g / 0.46 lbs (Size M)
  • Weight 120g / 0.26 lbs (Size S)
  • Dimensions (L x W x H) 450 x 350 x 5 mm (Size L)
  • Dimensions (L x W x H) 320 x 270 x 5 mm (Size M)
  • Product Name Speed-RX
  • Dimensions (L x W x H) 250 x 210 x 5 mm (Size S)
  • Product Number SGS-4030-KLMM1 (Size L)
  • Product Number SGS-4020-KMMM1 (Size M)
  • Product Number SGS-4010-KSMM1 (Size S)
