Stryker SE image number 0
Stryker SE image number 1
Stryker SE image number 2
Stryker SE image number 3
Stryker SE image number 4
Stryker SE image number 5
Stryker SE
Stryker SE
Stryker SE
Stryker SE
Stryker SE
Stryker SE
BUILD YOUR GAMING EXPERIENCE
Stryker SE
Stryker SE
  • Materials Steel
  • Radiator Support - Bottom 120mm
  • Dust Filters Top
  • Cable Routing 17.9mm
  • Pre-installed Fans - Rear 1x 140mm, 1200RPM
  • Pre-installed Fans - Top 1x 200mm
  • Fan Support - Bottom 2x 120mm
  • Legacy Cases
  • Dust Filters Front
  • Expansion Slots 9+2
  • Radiator Support - Bottom 140mm
  • Radiator Support - Rear 140mm
  • Materials Plastic
  • 3.5" Drive Bays 2
  • I/O Panel 2x USB 3.0
  • Materials Tempered Glass
  • 5.25" Drive Bays 1
  • Color(s) White
  • Radiator Support - Bottom 240mm
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Drive Bays - 2.5" SSD 4 + 1 (from X-Dock)
  • Motherboard Support XL-ATX
  • Dimensions (L x W x H) 578.5 x 250 x 605.6mm
  • Pre-installed Fans - Front 2x 120mm White LED Fan (1200RPM)
  • EAN Code 4719512065402
  • UPC Code 884102037924
  • Motherboard Support E-ATX
  • I/O Panel 2x USB 2.0
  • Motherboard Support ATX
  • Fan Support - Top 1x 200mm
  • Clearance - GFX 322mm
  • Clearance - CPU Cooler 186mm
  • I/O Panel Fan Speed & LED on/off buttons
  • Model Number SGC-5000W-KWN2
