Vortex 211P CPU Air Cooler image number 0
Vortex 211P CPU Air Cooler image number 1
Vortex 211P CPU Air Cooler image number 2
Vortex 211P CPU Air Cooler image number 3
Cooler Master Vortex 211P is a low profile CPU cooler with just 58mm height able to fit in HTPC chassis and LAN box chassis.
  • Fan Life Expectancy 40,000 Hours
  • Connector 3-Pin
  • Rated Voltage 12 VDC
  • Legacy Cooling
  • CPU Support Core™ i7
  • CPU Support Core™ i5
  • CPU Support Core™ i3
  • Bearing Type Rifle Bearing
  • Fan Dimensions (L x W x H) 94 x 94 x 16.5 mm
  • CPU Socket LGA1200
  • CPU Support Pentium
  • CPU Support Celeron
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Heat Sink Material 2 Heat Pipes
  • CPU Socket LGA775
  • Power Consumption 2.88W
  • Fan Rated Current 0.24A
  • Fan Airflow 38.3 CFM ±10%
  • Weight 230g
  • Fan Noise Level 26 dBA
  • Fan Air Pressure 1.51 mmH2O ± 10%
  • Fan Speed 2200 RPM ± 10%
  • Dimensions (L x W x H) 102.4 x 96.4 x 58 mm
  • Product Number RR-V211-22FK-R1
