X Dream K641 image number 0
X Dream K641 image number 1
X Dream K641
X Dream K641
X Dream K641
X Dream K641
  • Cooler Type Air Cooler
  • Fan Life Expectancy 40,000 Hours
  • Connector 3-Pin
  • Rated Voltage 12 VDC
  • Start Voltage 7 V
  • Legacy Cooling
  • Operating Voltage 5-13.8 V
  • Fan Bearing Type LDB
  • Rated Current 0.14A
  • Fan Dimensions (L x W x H) 80 x 80 x 25 mm / 3.1 x 3.1 x 1.0 inch
  • Series X Dream
  • Power Consumption 1.68W
  • Fan Airflow 30 CFM ± 10%
  • CPU Support AMD Athlon™ X2
  • CPU Socket AM2
  • CPU Support AMD Sempron™
  • CPU Socket 940
  • CPU Socket 939
  • Heat Sink Dimensions (L x W x H) 77 x 79 x 45 mm
  • Heat Sink Material Aluminum Alloy
  • CPU Socket 754
  • Fan Noise Level 19 dBA
  • Weight 418g
  • Fan Air Pressure 3.1 mmH2O
  • Fan Speed 2200 RPM ± 10%
  • Dimensions (L x W x H) 86 x 86 x 72 mm
  • Product Number RR-KEE-L8E1-GP
