X Dream L115 CPU Air Cooler image number 0
X Dream L115 CPU Air Cooler image number 1
Cooler Master X Dream L115 is a extremely low profile CPU cooler designed for a system with limited space.
  • Connector 3-Pin
  • Fan MTTF 40,000 Hours
  • Rated Voltage 12 VDC
  • Legacy Cooling
  • Fan Dimensions (L x W x H) 80 x 80 x 15 mm / 3.2 x 3.2 x 0.6 inch
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Fan Rated Current 0.15A
  • Heat Sink Material Aluminum Extruded Heat Sink + Copper Core
  • Fan Power Consumption 2.16W
  • Fan Rated Current 0.18A
  • Heat Sink Dimensions (L x W x H) Ø91 x 34mm
  • Weight 222g (With Backplate)
  • Fan Noise Level 25 dBA
  • Fan Air Pressure 1.03 mmH2O
  • Fan Speed 2200 RPM ± 10%
  • Fan Airflow 22.98 CFM
  • Product Number RR-X115-22FK-R1
