Xornet II image number 0
Xornet II image number 1
Xornet II
Xornet II
THE BEST OPTICAL GAMING MOUSE DESIGN FOR CLAW GRIP
Xornet II
  • Mouse Cable Length 1.8m / 70.9 in
  • Mouse Connector Cable USB 2.0
  • Mouse LED Color RGB
  • Mouse Color Black
  • Mouse Grip Type Claw
  • Programmable buttons 7
  • Programmable Profiles Not Available
  • Mouse acceleration 20g
  • Mouse Lift Off Distance < 3mm
  • Angle Snapping No
  • Legacy Peripherals
  • Mouse Memory 8 KB
  • Mouse Material Plastic
  • Mouse Tracking Speed 80 ips / 20 g
  • Mouse Material Rubber
  • Mouse Sensor Avago 3320 Optical Sensor
  • CPI / DPI 3 Levels / Up to 3500 DPI setting
  • Mouse Dimensions 105.4 x 76.6 x 37.2 mm / 4.15 x 3.01 x 1.46 inches (L x W x H)
  • Mouse Weight 132g / 0.291 lbs
  • Mouse Weight 80g / 0.177 lbs (without USB Cable)
  • Product Name Xornet II
  • Product Number SGM-2002-KLON1
