Dyn X Accessories image number 0
Dyn X Accessories image number 1
Dyn X Accessories image number 2
Dyn X Accessories image number 3
Dyn X Accessories image number 4
Dyn X Accessories
Dyn X Accessories
Dyn X Accessories
Dyn X Accessories
Dyn X Accessories
Dyn X Accessories
Dyn X Motion System
隆重推出 Cooler Master Dyn X Motion System:動態模擬領域的一大躍進,專為模擬賽車與飛行模擬的愛好者及專業人士打造。憑藉更大的馬達與致動器,我們的動態系統能支撐更大的重量,並帶來強勁且扭力增強的體感,使其成為商業應用的理想選擇。作為高度可靠的工業級系統,它透過先進的訊號處理提供極為逼真的載具動態回饋。以無與倫比的擬真度,體驗每一次高度變化、載具移動、路面變化與換檔。
Dyn X Motion System
Dyn X Motion System
專業運動系統
提供極為逼真的車輛運動回饋。
DYN X 致動器安裝座特色
廣泛的相容性
觸覺回饋
電子安裝托盤
簡單輕鬆安裝
靈敏的觸發鍵程
提供最大 2 吋(50mm)的可調行程。
堅固耐用的結構
特別大直徑的活塞,搭配以鋁製外殼加工而成的整塊金屬(billet),打造出經久耐用的品質。
大承重能力
最高可承重 800 lbs.(363 kg)。
Cooler Master x  Simucube 2 Pro Co-brand Direct Drive Wheelbase
The Cooler Master x Simucube 2 Pro Co-brand Direct Drive Wheelbase represents a new cutting-edge advancement in sim racing gear designed for elite racers and dedicated enthusiasts. The Cooler Master x Simucube 2 Pro Wheelbase revolutionizes the racing simulation experience with its unparalleled precision and immersive force feedback, driven by a high-torque, brushless motor. Engineered for excellence, this wheelbase redefines expectations, offering an unmatched level of realism and engagement in the virtual racing world.
Dyn X Actuator Mount
Broad Compatibility
Works with most available actuators including Cooler Master, Sigma Integrale, D-BOX, and Qubic System.
Haptic Feedback
The Dyn X and actuator mounts were developed together to effectively provide immersive haptic feedback.
Electronic Mounting Tray
Includes a mounting tray for use with most available actuator controller boxes, such as those listed above.
Simple And Easy Installation
Both the actuator mounts and the electronic mounting tray quickly bolt onto the Dyn X frame.
Dyn X Cockpit Monitor Mount​
Wide Range Of Compatibility
Compatible with monitors with VESA 75x75mm or VESA 100x100mm, majority of monitors in the market.
Supports up to single 49” ultra wide (32:9) monitor.
Seamless Integration
Single monitor stand that can be directly installed and integrated with the Dyn X cockpit.
Works with Dyn X at any driving position it can simulate.
Dyn X Shifter & Handbrake Mount​
Compatible with multiple shifter and handbrake brands and models, as well as flight simulators’ stick and throttle.
Flexible Adjustment
Mounts can be adjusted to user’s favorite position and installed on either side of Dyn X, supporting both right-handed and left-handed users.
Tough Durability
Made for a durable, solid steel
Dyn X Flight Mount Upgrade Kit
Flexible Adjustment
Tough Durability
Dyn X Steering Mount Adapter
Add support for many more models of front mount wheelbases.
High Durability
Durable as expected from Dyn X professional sim racing cockpit.
Dyn X Steering Side Mount
Personalized Adjustment
Multi-adjustable design allows you to experience the most realistic yet comfortable driving position.
Quality Build
Solid structure and thick-walled carbon steel enables you to conquer every curve without compromise.
Dyn X Steering Tray Mount
Quality Build
Dyn X Quick Release
Dyn X Quick Release
Seat Adjustment
A simple and tool-less seat adjustment solution in addition to the seat slider allows for customization without sacrificing haptic feedback.
High Durability
Comes with a tough, stainless-steel handle capable of withstanding applied pressure.
Dyn X Speaker Mount
Dyn X Speaker Mount
Flexible Adjustment
360-degree adjustable design allows for ultimate flexibility
High Build Quality
An Aluminum Alloy and Stainless Steel build allow for long hours of use.
