GA22FC image number 0
GA22FC image number 1
GA22FC image number 2
GA22FC image number 3
GA22FC image number 4
GA22FC image number 5
GA22FC
GA22FC
GA22FC
GA22FC
GA22FC
GA22FC
Your Everyday Work and Play Companion
GA22FC
The GA22FC is designed for office workers and gamers alike who want to enjoy a seamless and leveled-up everyday experience.
With a 21.45” FHD display, 4000:1 high contrast ratio, and a 100Hz refresh rate, the GA22FC meets the needs of both light esports and daily work. It is the perfect choice for an entry-level display with high-value performance.
Workers and Players Unite
The GA22FC has been crafted as a daily workhouse and
companion for gaming, working, and entertainment.
It offers several visual modes such as Act, FPS, RTS, User,
Standard, Web, Text, and Movie, as well as Adaptive Sync
for smooth and tear-free visuals. These numerous options
provide users of all kinds with the flexibility they need to
get anything done.
EXPERIENCE BETTER GAMING SESSIONS
The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
All-Day Comfort
A low blue light display mode reduces the amount of potentially harmful blue light, while a flicker-free function provides a stable display, putting your mind at ease during long sessions.
MULTIPLE CONNECTIONS
Connect your devices with I/O ports consisting of:
• HDMI 1.4
• VGA
• Power
  • 產品型號 CMI-GA22FC
  • 螢幕尺寸 21.45"
  • 長寬比 16:9
  • 面板類型 平面系列
  • 面板 VA 16.7M
  • 解析度 FHD 1920x1080
  • 更新率 100 Hz
  • 對比度 4000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 250 nits (Typical)
  • HDR N/A
  • HDR Peak 亮度 N/A
  • 調光分區 N/A
  • 色域 sRGB 105% (Typ., CIE 1931)
  • 色域 DCI-P3 75% (Typ., CIE 1976)
  • 色域 Adobe RGB 73% (Typ., CIE 1931)
  • 介面 (輸入/輸出) - VGA 1
  • 介面 (輸入/輸出) - HDMI 1.4 1
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • 超載 支援
  • VRR 技術 Adaptive Sync
  • 反應時間 4ms (GtG)
  • 反應時間 1ms (MPRT)
  • 護眼功能 低藍光 (S/W)
  • 不閃屏 N/A
  • 介面 (輸入/輸出) - 喇叭 N/A
  • KVM N/A
  • PIP/PBP (畫面分割) N/A
  • 功耗 24W (Max)
  • VESA 100x100 mm
  • 傾仰調整範圍 -5°~+20°
  • 旋轉調整範圍 N/A
  • 高度調整範圍 N/A
  • 支架調整範圍 N/A
  • Cooler Master 散熱設計 N/A
  • 螢幕系列 GA系列
  • 產品分類 電競螢幕
  • Panel Type VA
