GM27-CFX 27" Curved Gaming Monitor image number 0
GM27-CFX 27" Curved Gaming Monitor image number 1
GM27-CFX 27" Curved Gaming Monitor image number 2
GM27-CFX 27" Curved Gaming Monitor image number 3
GM27-CFX 27" Curved Gaming Monitor image number 4
GM27-CFX 27" Curved Gaming Monitor image number 5
GM27-CFX 27" Curved Gaming Monitor image number 6
GM27-CFX 27" Curved Gaming Monitor image number 7
GM27-CFX 27" Curved Gaming Monitor image number 8
GM27-CFX 27" Curved Gaming Monitor image number 9
GM27-CFX 27" Curved Gaming Monitor image number 10
Immerse Yourself in the Gaming World
GM27-CFX 27" Curved Gaming Monitor is a high-powered staple tool in your daily life for gaming, working, and entertaining.
立即購買
  • 產品型號 CMI-GM27-CFX
  • 曲率 1500R
  • 長寬比 16:9
  • 螢幕尺寸 27"
  • 面板 VA 8bit w/ Quantum dot
  • 解析度 FHD 1920x1080
  • 更新率 240 Hz
  • 對比度 3000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 400 nits (Typical)
  • HDR400 Compatible
  • 色域 DCI-P3 98%
  • 介面 (輸入/輸出) - DP 1.2版 1
  • 介面 (輸入/輸出) - HDMI 2.0 2
  • 介面 (輸入/輸出) - 喇叭 2 (2W)
  • DCR (Dynamic Contrast Ratio) 動態對比 Yes
  • VRR 技術 Adaptive Sync, FreeSync Range: Yes, G-Sync Range: Yes
  • 反應時間 0.5ms (MPRT)
  • 護眼功能 Low Blue Light
  • 不閃屏 Yes
  • 超載 Yes
  • 功耗 18W (Typ.)**
  • VESA 100x100 mm
  • 高度調整範圍 0-130 mm
  • 旋轉調整範圍 -15°~+15°
  • 傾仰調整範圍 -5°~+20°
  • 產品分類 Gaming Monitor
  • 螢幕系列 GM Series
  • 面板類型 Curved Series
  • 說明 * All may vary by models and region. Specifications and features are subject to change without notice.
  • 說明 ** Measure a screen brightness of 200nits without audio/USB/Card reader connection.
  • Panel Type VA
