GM27QPA image number 0
GM27QPA image number 1
GM27QPA image number 2
GM27QPA image number 3
GM27QPA image number 4
GM27QPA image number 5
GM27QPA
GM27QPA
GM27QPA
GM27QPA
GM27QPA
GM27QPA
Maximize Every Moment of Work and Play
GM27QPA
Introducing the GM27QPA, Cooler Master’s latest flat-screen monitor designed to accompany you through your daily tasks, whether it be business or fun. The GM27QPA has been designed with a focus on crisp display tech, fluid response time, and color vibrancy, as well as comfort for users looking to pull long sessions. No matter your need, the GM27QPA has got your back all day every day.
A Screen Fit For All Kind of Needs
At 27 inches with IPS panel, the GM27QPA has ample room for users of all kinds. Whether you are a hardcore gamer, avid movie watcher, detail-oriented graphic designer, or multi-tasking office worker, the GM27QPA has the space you need.
Crisp Display
With QHD resolution, you’ll see details previously unseen. Moving your eyes from the world around you to the screen, you’ll hardly notice a difference. Whether you are an FPS gamer looking to really enter into other worlds or a graphic designer trying to maximize your productivity, the GM27QPA will show you details you didn't even know existed.
Crisp Display
Crisp Display
Experience Better Gaming Sessions
The Adaptive Sync feature ensures smooth visuals, even when the frame rate fluctuates.
Built-In Dual Speakers
Experience sound entertainment with 2 built-in speakers- no need for extra peripherals. Save desk space and streamline your setup for efficient work, learning, and play.
Comfort Day and Night
A Low Blue Light Display mode and Flicker Free function ensure the GM27QPA remains easy on the eyes, even during extra long sessions.
Multiple Connections
Connect your devices with I/O ports consisting of:
• HDMI 2.0 x2
• DisplayPort 1.4 x1
• Audio Out
• Power
  • 產品型號 CMI-GM27QPA
  • 面板類型 平面系列
  • 螢幕尺寸 27"
  • 長寬比 16:9
  • 解析度 2K QHD 2560x1440
  • 更新率 240 Hz
  • 對比度 1000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 350 nits (普通)
  • HDR HDR400
  • HDR Peak 亮度 400 nits
  • 調光分區 N/A
  • 色域 DCI-P3 93% (Typ., CIE 1976), sRGB 97% (Typ., CIE 1931)
  • 介面 (輸入/輸出) - DP 1.4 1
  • 介面 (輸入/輸出) - HDMI 2.0 2
  • 介面 (輸入/輸出) - 3.5mm 音源輸出 1
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • 超載 支援
  • VRR 技術 Adaptive Sync
  • 反應時間 1ms (MPRT), 5ms (GtG)
  • 護眼功能 低藍光 (S/W)
  • 不閃屏 支援
  • 介面 (輸入/輸出) - 喇叭 2 (3W)
  • KVM N/A
  • PIP/PBP (畫面分割) 支援
  • 燈光 N/A
  • 功耗 46W (Max)
  • VESA 75x75 mm
  • 傾仰調整範圍 -5°~+20°
  • 旋轉調整範圍 ±15°
  • 高度調整範圍 110mm
  • 支架調整範圍 0-90°
  • Cooler Master 散熱設計 N/A
  • 產品分類 電競螢幕
  • 螢幕系列 GM系列
  • Panel Type IPS
