GM34-CWQ ARGB 34" Curved Gaming Monitor image number 0
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 1
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 2
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 3
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 4
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 5
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 6
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 7
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 8
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 9
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 10
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 11
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 12
GM34-CWQ ARGB 34" Curved Gaming Monitor image number 13
Feel the Immersion
The GM34-CWQA is designed for everyone and offers outstanding value and competency with WQHD resolution that empowers your work/play experience
立即購買
CUSTOMIZED HDR MODES
After activating HDR, you can choose from three HDR modes: Standard, Game, and Movie. Standard HDR mode allows you to adjust R/G/B color values, as well as brightness and contrast to better suit your preferences. Game and Movie HDR modes have preset configurations to optimize the HDR viewing experience based on your content.
SPEED AND RELIABILITY
With a 144Hz refresh rate combined with an ultra-fast 0.5ms (MPRT) response time, your games will look clearer than ever before. Track enemies with precision and dominate the battlefield as your enemies struggle to keep up with your speed.
MASTERPLUS+
MASTERPLUS+
Using the MasterPlus+ app, you can fully customize the ARGB lighting built into the Halo stand. Set specific colors for certain occasions as well as synchronize lighting to your other compatible Cooler Master peripherals.
Download
TYPE C VERSATILITY
TYPE C VERSATILITY
A single USB Type C port is built into the monitor, providing up to 65W PD power output which can fully charge your devices such as a laptop or other USB C compatible devices. It also supports signal display out via DisplayPort 1.4, so you can charge and connect your laptop or device to an external display all through one USB C cable only.
Swivel: -15°~+15°
Height: 0~80mm
TILT: -5°~+15°
CLEAN & MINIMAL AESTHETIC
Whether you're at the office, or in your gaming cave, the GM34-CWQ ARGB has a clean design with minimal branding that can fit perfectly in any setup.
• Height: 0-80mm
• Swivel: -15°~+15°
• Tilt: -5°~+15°
AMPLE CONNECTIVITY AND I/O
Connect all your devices with the wide range of I/O ports consisting of:
• 1 x DisplayPort
• 2 x HDMI
• 1 x USB Type C (65W PD, DP1.4)
• 2 x USB Type A
• 2 x 5W built-in speakers
• 1 x 3.5mm headphone jack
  • 產品型號 CMI-GM34-CWQA
  • 曲率 1500R
  • 長寬比 21:9
  • 螢幕尺寸 34"
  • 面板 VA 8bit 量子點
  • 解析度 UWQHD 3440x1440
  • 更新率 144 Hz
  • 對比度 4000:1
  • 可視角度 (H/V) 178°/178°
  • 亮度 400 nits (典型值)
  • HDR400 相容
  • 色域 DCI-P3 98%
  • 介面 (輸入/輸出) - DP 1
  • 介面 (輸入/輸出) - HDMI 2.0 2
  • 介面 (輸入/輸出) - 喇叭 2 (5W)
  • 介面 (輸入/輸出) - USB Type C 1 (PD 65W)
  • 介面 (輸入/輸出) - USB 3.0 Type B 1
  • 介面 (輸入/輸出) - USB 3.0 Type A 2
  • DCR (Dynamic Contrast Ratio) 動態對比 支援
  • VRR 技術 FreeSync Premium, FreeSync Range: Yes, G-Sync Range: Yes
  • 反應時間 0.5ms (MPRT)
  • 護眼功能 低藍光
  • 不閃屏 支援
  • 超載 支援
  • 燈光 ARGB
  • 功耗 31W (Typ.)**
  • VESA 100x100 mm
  • 高度調整範圍 0-80 mm
  • 旋轉調整範圍 -15°~+15°
  • 傾仰調整範圍 -5°~+15°
  • 產品分類 電競螢幕
  • 螢幕系列 GM系列
  • 面板類型 曲面系列
  • 說明 * 所有可能因型號和地區而異。規格和功能如有變更,恕不另行通知。
  • 說明 ** 在沒有音源/USB/讀卡器連接的情況下,測量亮度為200 nits 的螢幕。
  • Panel Type VA
