HAF 700 image number 0
HAF 700 image number 1
HAF 700 image number 2
HAF 700 image number 3
HAF 700 image number 4
HAF 700 image number 5
HAF 700 image number 6
HAF 700 image number 7
HAF 700 image number 8
HAF 700 image number 9
HAF 700 image number 10
HAF 700 image number 11
HAF 700 image number 12
HAF 700 image number 13
HAF 700 image number 14
HAF 700 image number 15
HAF 700 image number 16
HAF 700 image number 17
HAF 700 image number 18
HAF 700 image number 19
HAF 700 image number 20
HAF 700 image number 21
HAF 700 image number 22
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
HAF 700
狂戰士
HAF 700
HAF 700特別採用多艙式機身設計,搭配雙ARGB 200mm Sickleflow風扇,為系統進行標靶散熱,迅速排除熱源。讓任何您所安裝的配件都得以高效運作,輕鬆造就非凡的使用體驗。
顏色
立即購買
IN SPIRIT OF COOLER MASTER'S HAF LEGACY
HAF 700 embodies the spirit of HAF's performance oriented design, boasting attention to mechanical detail.
Our Achievements
14 AWARDS
No Limits
Hardware & Connectivity
No Limits
The HAF 700 is capable of housing up to SSI-EEB motherboards (E-ATX), as well as any sized graphics cards in BOTH horizontal and vertical orientations.
Rich Connectivity
Rich Connectivity
The front I/O is designed to maximize the front connectivity for most high end motherboards, featuring four USB Gen 3.1 Type A ports, a USB Gen 3.2 Type C, a 4 pin audio/mic headset jack as well as a dedicated mic jack.
Custom Cooling
6x
MAMMOTH RADIATOR SUPPORT
Fans
Exclusive SickleFlow fans
HAF 700 comes with dual exclusive 200mm Sickleflow ARGB PWM "Performance Edition" fans tailored to strike a balance between performance potential and noise levels
Unrestricted Front Panel Intake
HAF 700 sports a fully meshed front panel, specifically designed to allow for maximum air intake. With the front panel structurally reinforced to prevent resonation caused by fan vibrations, systems can run smoothly at minimal noise levels.
Effortless Management
12x
INTEGRATED HUB
Installation
ADVANCED MOUNTING OPTIONS
The unique removable top panel design allows you to effortlessly install, reach and maintain cooling components such as fans and radiators even in builds with complex custom cooling systems. This, coupled with the rotatable radiator/fan bracket included out of the box allows for an unparalleled building experience.
Software
MASTERPLUS+ SOFTWARE INTEGRATION
Design
TOOL-LESS INSTALLATION
Design
MULTI CHAMBER LAYOUT
HAF 700's structure segregates non heat sensitive components so heat dissipation can be targeted towards heat sensitive components at an overall higher efficiency.
  • 產品型號 HAF 700: H700-IGNN-S00, HAF 700 WHITE: H700-WGNN-S00
  • 外觀顏色 Titanium Grey, White
  • 材質 - 外部 Steel, Plastic
  • 材質 - 左側板 Tempered Glass, Steel, Plastic
  • 尺寸 (長x寬x高) 556 x 279 x 540 mm (本體)
  • 尺寸 (長x寬x高) 666 x 291 x 626 mm (包含突出部位)
  • 主機板支援 Mini-ITX, Micro-ATX, ATX, E-ATX, SSI-CEB, SSI-EEB
  • PCI 擴充槽 8
  • 2.5"/3.5" 硬碟架 (複合式) 9 (4*HDD bracket, 5*Screw+Rubber)
  • I/O 面板 - USB 埠 1x USB 3.2 Gen 2 Type C, 4x USB 3.2 Gen 1 (3.0)
  • I/O 面板 - 音效輸入/輸出 1x 3.5mm 4 Poles Audio Jack, 1x 3.5mm Mic Jack
  • 預裝風扇 - 前方 2x SickleFlow 200 ARGB PWM
  • 預裝風扇 - 後方 2x SickleFlow 120 ARGB PWM
  • 預裝風扇 - 底部 1x SickleFlow 120 ARGB PWM
  • 風扇支援 - 上方 2x 200mm, 3x 140mm, 6x 120mm (Remove 480mm bracket)
  • 風扇支援 - 前方 2x 200mm
  • 風扇支援 - 後方 2x 120mm
  • 風扇支援 - 底部 3x 120/140mm
  • 風扇支援 - 側面 4x 120mm / 3x 140mm
  • 水冷支援 - 上方 最高可支援 2x 360mm / 1x 420mm
  • 水冷支援 - 後方 最高可支援 240mm
  • 水冷支援 - 底部 最高可支援 420/360mm
  • 水冷支援 - 側面 最高可支援 480/420/360mm
  • 預留安裝空間 - CPU 散熱器 166mm
  • 預留安裝空間 - 電源供應器 200mm
  • 預留安裝空間 - 顯示卡 490mm
  • 電纜佈線 - 主板托盤後面 90-101mm
  • 包含配件 1x Rotatable Radiator Bracket, 1x LED Controller A1 (ARGB Gen2), 1x ARGB/PWM Hub
  • 防塵濾網 Bottom, Right Side
  • 電源供應器類型 Bottom Mount, ATX
  • 保固 2 年
  • 尺寸 高直立式
  • 系列 HAF 系列
  • 備註 * 支援一般 30mm 厚度水冷排, 如使用加厚的水冷排, 請參考相容性列表
