HAF X
HAF X
尺寸Full Tower
材質Steel
散熱器支援度 - 前方230 x 30mm Red LED Fan x 1 / 700 RPM / 19 dBA
散熱器支援度 - 側板230 x 30mm Standard Fan x 1 / 700 RPM / 19 dBA (Supports 120mm Fan x 4)
散熱器支援度 - 後方140 x 25mm Fan x 1, 1200 RPM, 17 dBA (Supports 140mm Fan)
散熱器支援 - 顯卡風扇管道1x 120x25mm or 120x38mm Fan (Optional)
散熱器支援 - 顯卡固定座1x 80x15mm Fan (Optional)
散熱器支援度 - 前方200 x 30mm fan x 2 (one is optional)
LegacyCases
I/O 面板2x USB 3.0
電源供應器類型ATX
周邊 4 Pin 電源接頭9
2.5" 硬碟架2 (from 5.25" drive bays)
主機板支援XL-ATX
SATA 電源接頭9
電源供應器類型ATX PS2
I/O 面板2x USB 2.0
主機板支援E-ATX
主機板支援ATX
顏色Midnight Black
尺寸 (長x寬x高)230 x 599 x 550 mm / 9.1 x 23.6 x 21.7 inch
5.25" 硬碟架6 (2 from X-Dock)
材質Polymer
主機板支援Micro ATX
系列HAF Series
材質Mesh
3.5" 硬碟架5 (hidden) (supports 2-in-1 2.5" and 1.8" SSD)
I/O 面板1x e-SATA
I/O 面板1x IEEE 1394a
I/O 面板1x Mic
I/O 面板1x Audio (supports HD audio)
最大相容性 - 顯卡長度342mm / 13.5 inch
最大相容性 - CPU 散熱器高度190mm / 7.5 inch
重量14.35 kg / 31.6 lbs
產品型號RC-942-KKN1
Confirm your Country
It looks like you're in
