5.25" 硬碟架1 (The max. length of 5.25" device: 170mm / 6.7")
3.5" 硬碟架3 (hidden)
2.5" 硬碟架2 (hidden, in the HDD cage)
PCI 擴充槽7
I/O 面板 - USB 埠1x USB 3.0, 1x USB 2.0
I/O 面板 - 音效輸入/輸出1x Audio (supports AC97 Only)
風扇支援 - 前方1x 120mm Black Fan
風扇支援 - 後方1x 120mm Black Fan (Optional)
風扇支援 - 側面2x 120mm Fan (Optional)
預留安裝空間 - CPU 散熱器160mm (w/o 12025 mm Side Fan), 135mm (with 12025 mm Side Fan)
預留安裝空間 - 顯示卡345mm (w/o 12025 mm Front Fan), 320mm (with 12025 mm Front Fan)
主機板支援ATX PS2 (Max. length: 180 mm)
��寸Mid Tower
系列Others
Confirm your Country
It looks like you're in
