Cooling X image number 0
Cooling X image number 1
Cooling X image number 2
Cooling X image number 3
Cooling X image number 4
Cooling X image number 5
Cooling X image number 6
Cooling X
Cooling X
Cooling X
Cooling X
Cooling X
Cooling X
Cooling X
Cool. Compact. Quiet.
Cooling X
Cooling X is Cooler Master’s first complete PC delivering all in one liquid cooling in a compact format.
U.S. Shipping:
Ships from California
$3,999.99
Cooler Master Cooling X is a desktop PC like no other. Its unique liquid cooling solution has been redesigned to make Cooling X compact, cool and silent. Both the CPU and GPU are efficiently cooled through a copper water block which effectively removes heat and channels it towards a 240 mm radiator and liquid-cooled side panels. These components work seamlessly to dissipate heat, resulting in enhanced performance and durability. Cooling X stands as the ultimate tool for gamers and creators who demand nothing but the best.
CPU
RYZEN 9 7950X3D
Equipped with AMD Ryzen™ 9 7950X 3D CPU, with 16 cores, 32 threads and up to 5.7GHz clock speed, it is the ideal processor for gamers and creators. The processor is cooled with a water block, so heat is removed by liquid cooling and performance is optimized.
Extremely Quiet
28DB
FULL LOAD
Port & Slots
19
1/0 PORTS
GPU
RTX 4080
Cooling X is equipped with NVIDIA® GeForce™ 4080 graphics card. It's powered by the ultra-efficient NVIDIA Ada Lovelace architecture and 16GB of superfast G6X memory. For increased and stable gaming performance, the GPU is covered by a water block to remove the heat effectively.
Yes, it is really this  compact
Dimensions, weight & volume
1. WIDTH: 149.4 mm (5.9")
2. LENGTH: 266.0 mm (10.5")
3. HEIGHT: 371.6 mm (14.6")
NET WEIGHT: 17.3 KG (38.1 LBS)
VOLUME: 14.77 L (3.2 GAL)
  • Collection Cooling X
  • Product Number ASP-CXA9-N86CN-R1
  • Cooling Liquid Cooled CPU and GPU with 240 mm radiator and liquid cooled side panels
  • CPU Liquid Cooled AMD Ryzen™ 9 7950X 3D
  • Chipsest AMD B650
  • GPU NVIDIA GeForce RTX™ 4080
  • RAM 2 x 32GB Dual Channel DDR5-5600
  • Storage 2 x 2TB PCIe 4.0 NVMe M2
  • Ethernet 2.5Gbps LAN
  • Wireless AMD Wi-Fi 6E
  • Bluetooth Version 5.2
  • Power Supply Unit Cooler Master V850 SFX Gold
  • Top IO Ports 2 x USB 3.2 Gen 1.5 Gbps (Type-A), 1 x 2.5 Gbps LAN, 1 x 7.1 Channel Audio, 1 x HDMI 2.1a (up to 4K), 3 x USB 3.2 Gen 2 10 Gbps (Type-A), 1 x USB 3.2 Gen 2 x 2 20 Gbps (Type-C)
  • Rear IO Ports 3 x DisplayPorts 1.4a (up to 8K), 1 x HDMI 2.1a (up to 4K), 2 x USB 3.2 Type-A, 1 x USB 3.2 Type-C
  • Operating System Windows 11 Pro
  • Size (L x W x H) 276.1 x 175 x 379.84 mm (incl. Protrusions), 276.1 x 138.5 x 379.84 mm (excl. Protrusions)
  • Weight 17.3 kg / 38.1 lbs
  • Volume 14.77 L / 3.2 gal
  • Warranty 2 Years
  • Accessories AC Adapter, Warranty Card, Quick Start Guide
