MasterFrame 360 Panorama S Limited Edition image number 0
Pre-order the MasterFrame 360 Panorama S Limited Edition full system now.
See full specs
Pre-order Price: USD $3,099.99 (was $3,599.99 ) – Free Delivery
Shipping Update:
Your order is currently on its way to your address.
For updates or assistance, please feel free to contact our D2C support team through our official website or other authorized channels.
(Shipping outside the US or EU?
Please [click here] to place your order through the regional site.)
U.S. Shipping:
Ships from California
Price reduced from $3,599.99 to $3,099.99
Turn your rig into a Stage.
The front display stage transforms your PC into a personal showcase - perfect for collectibles, figures, and decorations that reflect your style.
Designed to Showcase. Built to Inspire.
Designed to spotlight your hardware, collectibles, and creativity - MasterFrame 360 Panorama provides a platform to transform your gaming rig into a personal showcase.
Vision Image
Hidden Image
Crystal Clear Design.
Show every detail that defines your build, from powerful hardware to your unique style, all in plain view.
From Vision to Reality.
The MasterFrame 360 Panorama showcases Cooler Master’s dedication to personalized expression. The concept was built on the original MasterFrame’s aluminum chassis modular design and further developed in collaboration with acclaimed PC modder “AK Mod” during COMPUTEX 2025. It underwent additional refinement through Cooler Master’s research and development team, ultimately leading to mass production.
The result is the MasterFrame 360 Panorama you see today.
What makes the MasterFrame 360 Panorama stand out.
Front Display Stage
Front display stage to showcase collectibles and add personal style to your limited edition rig.
Extreme Cooling Flexibility
Supports up to 12×120 mm, 4×140 mm, 4×180 mm, and 4×200 mm fans, or up to 4×360 mm radiators for ultimate thermal performance.
Wide Motherboard Compatibility
Supports Mini-ITX, Micro-ATX, ATX, and BTF with 110 mm cable clearance for clean, sleek setups.
Vertical GPU Support
Pre-installed PCIe 5.0 riser cable enables vertical GPU mounting, ensuring full accessibility of GPU aesthetics.
Priority Shipping & Early Access
Pre-order the exclusive MasterFrame 360 Panorama S Limited Edition - a prebuilt system with selected components, available only during this limited pre-order. It comes with the signature features of the iconic MasterFrame 360 Panorama Craft Edition case.
One of 100
Each unit features an individually numbered, laser-etched stainless steel nameplate for ultimate exclusivity.
Built for Performance
Dual-Chamber Layout
Keeps hardware and cables separated for a cleaner build.
Simplified I/O Panel
Essential ports with a minimal, streamlined design for easy access.
Dual ARGB Spotlights
Mounted on the front display stage to illuminate your collectibles with vivid ARGB lighting.
Pre-installed Nvidia Geforce RTX™ 5080 GPU
Powered by NVIDIA’s latest architecture, featuring fifth-gen Tensor Cores for advanced AI with FP4 and DLSS 4, fourth-gen Ray Tracing Cores for mega geometry, and new streaming multiprocessors tuned for neural shaders.
Pre-installed 12×120mm ARGB Fans
Comes with twelve 120mm ARGB fans, including SickleFlow Edge and Reverse Blade modules—pre-arranged for balanced airflow and synchronized lighting.
MasterLiquid Atmos II 360 LCD AIO Cooler
Features real-time status display on the pump cover and a patented dual-chamber pump design for improved cooling and reliability.
