Elite 360 image number 0
Elite 360 image number 1
Elite 360 image number 2
Elite 360 image number 3
Elite 360 image number 4
Elite 360 image number 5
Elite 360 image number 6
Elite 360 image number 7
Elite 360 image number 8
Elite 360
Elite 360
Elite 360
Elite 360
Elite 360
Elite 360
Elite 360
Elite 360
Elite 360
Built to Perform. Designed to Display.
Elite 360
• Open Showcase Stage
• 10.1” HD Screen
• Hot-Swappable & Removable Showcase Module
• High-Speed Front I/O
• Compact Volume Design
• Powerful Compatibility
U.S. Shipping:
Ships from California
BUILT TO PERFORM. DESIGNED TO DISPLAY.
The Elite 360 blends minimalist design with an open showcase concept, turning your PC into part of your desktop display. A dedicated showcase stage and integrated 10.1" screen bring personalization front and center, while spacious hardware support keeps performance uncompromised.
OPEN SHOWCASE STAGE
Your Build. Your Stage.
A dedicated front display chamber gives your favorite figures, collectibles, and personal touches a place beside your build.
10.1” HD SCREEN
Make It Yours.
Display system information, animated wallpapers, or custom visuals on the integrated 10.1" 1280 × 800 screen.
HOT-SWAPPABLE & REMOVABLE SHOWCASE MODULE
Swap. Style. Refresh.
The modular showcase chamber is removable and hot-swappable, making customization, cleaning, and reconfiguration effortless.
HIGH-SPEED TOP I/O
Speed Within Reach.
One 20Gbps USB Type-C port and dual USB 3.0 ports deliver fast, convenient connectivity for your everyday gear.
COMPACT VOLUME DESIGN
More Build. Less Footprint.
At just 39.16L, the Elite 360 makes efficient use of desk space while leaving plenty of room inside for powerful hardware.
POWERFUL COMPATIBILITY
Ready for Big Hardware.
Support for GPUs up to 425mm, CPU coolers up to 170mm, and ATX power supplies up to 250mm gives you room to build without holding back.
360MM RADIATOR SUPPORT
Cooling Built to Scale.
Top-mounted radiator support up to 360mm gives high-performance builds the cooling headroom they need.
TEMPERED GLASS SIDE PANEL
Performance on Display.
Tempered glass side panel puts your hardware on show while complementing the Elite 360’s clean architectural design.
  • Product Name Elite 360
  • Series Elite Series
  • Color Black
  • Model Number E360-KGNN-S00
  • Material - Exterior SPCC
  • Material - Side Panel(Left/Right) Left Side Panel - Gray Tempered Glass / Right Side Panel - Steel
  • Dimensions (L x W x H) - Excl. Panels / Protrusions / Feet 430 x 218 x 404mm
  • Dimensions (L x W x H) - Incl. Panels / Protrusions / Feet 465(585*)x 218 x 424mm
  • Dimensions (L x W x H) - Incl. Panels, Excl. Protrusions 450(570*)x218x422mm
  • Dimensions (L x W x H) - Total Volume (incl. Protrusions) 39.16 L
  • Hardware Support - Motherboard Support Micro-ATX / ITX
  • Hardware Support - Power Supply Support ATX
  • Hardware Support - Expansion Slots 5
  • Drive Bays - 3.5" Drive Bays 1
  • Drive Bays - 2.5" Drive Bays 1
  • I/O Panel - USB Ports 1 x USB Type C 20Gbps / 2 x USB 3.0
  • I/O Panel - Audio In / Out 1 x 3.5mm Combo
  • Fan Support - Top 3x 120mm / 2x 140mm
  • Fan Support - Bottom 2 x 120mm
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 360(Max thickness 45mm)/ 240 / 120 mm
  • Clearances - CPU Cooler 170mm
  • Clearances - Power Supply 250mm
  • Clearances - Graphics Card 425mm
  • LCD Screen - Size 10.1”
  • LCD Screen - Resolution 1280*800
  • Preinstalled Fan - Rear 1 x 120mm ARGB
  • Warranty 2 Years
