MasterBox Q300L image number 4
MasterBox Q300L image number 5
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
MasterBox Q300L
Choose Your Style
MasterBox Q300L
High Flexibility for System Building
Minimized Dimension with ATX PSU Support
Patterned Dust Filter
Clean Routing Space
Excellent Thermal Performance
Edge-to-Edge Acrylic Transparent Side Panel
Vertical and Horizontal position
U.S. Shipping:
Ships from California
$49.99
Patterned Magnetic Dustfilters
Special pattern on the dust filter creates a unique outlook for the chassis.
Modular I/O Panel
Modular I/O Panel
The I/O panel can be adjusted to six different locations. On both side of the body you can install the I/O panel at the front, top or bottom.
Edge-To-Edge Side Panel
Show off your build through the full size transparent side panel.
Multiple Positioning Options
The case can be put in vertical or horizontal position.
The open design of the perforated front, top and bottom guarantees excellent thermal performance
Clean Routing Space
Behind the motherboard tray, 28mm of space is offered for cable management.
  • Model Number MCB-Q300L-KANN-S00
  • Color(s) Black
  • Materials Steel, Plastic
  • Dimensions (L x W x H) 387 x 230 x 381mm
  • Expansion Slots 4
  • 5.25" Drive Bays 0
  • 3.5" Drive Bays 1
  • 2.5" Drive Bays 2
  • I/O Panel - Audio In / Out 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack
  • Fan Support - Top 2x 120mm
  • Fan Support - Rear 1x 120mm
  • Fan Support - Bottom 1x 120mm
  • Clearance - CPU Cooler 159mm
  • Clearance - PSU 160mm
  • Clearance - GFX 360mm
  • Dust Filters Bottom
  • Size Mini Tower
  • Series MasterBox Series
