V SFX Platinum 1100 image number 0
V SFX Platinum 1100 image number 1
V SFX Platinum 1100 image number 2
V SFX Platinum 1100 image number 3
V SFX Platinum 1100 image number 4
V SFX Platinum 1100 image number 5
V SFX Platinum 1100 image number 6
V SFX Platinum 1100 image number 7
V SFX Platinum 1100 image number 8
V SFX Platinum 1100 image number 9
V SFX Platinum 1100 image number 10
V SFX Platinum 1100 image number 11
V SFX Platinum 1100 image number 12
V SFX Platinum 1100 image number 13
V SFX Platinum 1100 image number 14
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
V SFX Platinum 1100
An SFX Revolution
V SFX Platinum 1100
• High power density
• Advanced thermal performance
• 80 Plus Platinum efficiency
• Fully modular cabling
• 10-year warranty
U.S. Shipping:
Ships from California
Price reduced from $279.99 to $239.99
AN SFX REVOLUTION
The V SFX Platinum is leading the industry as the first SFX unit to acheive 1300W, and includes top-tier features such as full compatibility with ATX 3.0 and both ITX and ATX cases, and new miniaturization technology that enhances thermal performance and increases power density.
AN SFX REVOLUTION
AN SFX REVOLUTION
MINI BUT MIGHTY
MINI BUT MIGHTY
Flat copper wiring on the DC-DC choke, flat transformer piling, an aluminum plate dissipation structure on the full-bridge LLC, and advanced manufacturing processes enhance overall miniaturization.
 ENHANCED DISSIPATION
The transformer, rectifier, full-bridge LLC, and EMI-inhibiting amorphous metal materials are fully integrated for advanced performance and heat dissipation.
ATX 3.0 support
12VHPWR CABLE
FULLY MODULAR CABLING
PSU CALCULATOR
  • Model MPZ-B001-SFAP-B**
  • Input Current 14-6.5A
  • Fan Size 92mm
  • Fan Bearing FDB
  • Hold Up Time ≥16ms at 70% Load
  • Regulatory TUV, cTUVus, CE, BSMI, FCC, CCC, EAC, UKCA
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 8
  • PCI-e 6+2 Pin Connectors 3
  • 12VHPWR Connector 1
  • 80 Plus Efficiency Platinum
  • Series V SFX Series
  • Category Above 750W
  • Form Factor SFX
  • Watts 1100W
  • ATX Version ATX 3.0
  • Input Voltage Range Full Range
