X Silent MAX Platinum 1300 image number 0
X Silent MAX Platinum 1300 image number 1
X Silent MAX Platinum 1300 image number 2
X Silent MAX Platinum 1300 image number 3
X Silent MAX Platinum 1300 image number 4
X Silent MAX Platinum 1300 image number 5
X Silent MAX Platinum 1300 image number 6
X Silent MAX Platinum 1300 image number 7
PRECISE SILENT POWER
• Equipped with an Ultra-Quiet Mobius Fan
• Active Bridge Rectifier replaces diodes
• Minimize Electromagnetic Noise
• Industrial-Grade Infineon IC
• Digital Power Management System
• 15-year warranty
  • In Stock
U.S. Shipping:
Ships from California
Price reduced from $459.99 to $399.99
Precise Silent Power
Introducing the X Silent MAX Platinum by Cooler Master, engineered with an acoustically optimized Mobius Fan, top-tier industrial IC components and our exclusive aluminum heatsink dissipation technology.
This combination not only achieves supreme silence, but also ensures a premium experience.
Mobius Fan
Supreme Silence
Our design integrates an ultra-silent Mobius fan with an exclusive aluminum
heat sink for improved cooling efficiency. Combined with unique inductors that
minimize electromagnetic noise, it ensures an exceptionally quiet experience.
Fully Modular Cabling
Modular cabling minimizes clutter, while the additional ports provide extra functionality.
Exclusive Design
Superior Cooling Performance
Our exclusive aluminum Thermal Mold efficiently disperses heat, while the ultra-silent Mobius fan strengthens the airflow to lower the temperature across the unit. This dual approach guarantees effective thermal management, maintaining optimal performance and extending the lifespan of the PSU.
Active Bridge Rectifier Boosts Efficiency 2%
The Active Bridge Rectifier, equipped with the Infineon CoolMOS, marks a significant advancement in power efficiency. This innovative combination not only conserves electricity, but also significantly reduces power loss, outperforming traditional bridge diodes. It's an ideal solution for users seeking eco-friendly, high-efficiency power supply units.
ATX 3.1 Support & two Dual-color 12V-2X6 Cables
Includes ATX 3.1 support and two dual-color 12V-2X6 connectors (with clear purple markings) help users confirm correct installation, preventing poor contact and power issues for enhanced safety and reliability.
  • Model MPS-D001-AFAP
  • Input Current 15-7.1A
  • Fan Bearing LDB
  • Fan Speed 2050 RPM
  • Hold Up Time ≥ 16ms
  • Regulatory cUL, TUV, CE, FCC, BSMI, CCC, EAC, RCM, UKCA/BIS, KC (based on region's request.)
  • EPS 4+4 Pin Connectors 1
  • EPS 8 Pin Connector 1
  • SATA Connectors 12
  • PCI-e 6+2 Pin Connectors 4
  • 12V-2x6 Connectors 2
  • USB 10P Connector 1
  • PMBus 5 Pin Connector 1
  • Series X Series
  • 80 Plus Efficiency Platinum
  • Category Above 750W
  • Watts 1300W
  • ATX Version ATX 3.1
  • Input Voltage Range Full Range
